Integration of Shelly Temperature Sensor (Shelly BLU HT) in HA
BTW - I understand you’re one of the “specialists” for integartion fo Shelly Devices into HA…
I actually do have another problem with a Shelly ProEM50 as well which I am struggling with - see this thread: Integration of Shelly ProEM50 into Homeassistant - YAML-scirpt does not work
The ProEM50 has to reading ports which I want to sum up to one reading…
The YAML-scirpt seem to work (I do not get any faliure reports or similar) but the “desired” entity doesn’t show up in the list of entities…
Maybe you might have a smart idea/hint to fix this as well?
I will now start reading the other paper you recomended!
In the meantime many thanks for your help and support!
Rolf
