Integration of Symcon 1-wire LAN-Gateway
Hi all, finally I´m migrating from IP-Symcon to Home Assistant and have a question about integrating the Symcon 1-wire LAN Gateway to Home Assistant.
I tried to use the 1-wire integration of HA but after setting the IP - Adress and Port (5000) nothing happens or to say: “Connection failed”. Has anybody got this gateway working?
Thanks, Peter
Looking at this, you would seem to be limited to talking to specific devices.
Perhaps share exactly what you tried and what protocol you think this Symcon is would help.
Hi, it´s this gateway: 1-Wire LAN Gateway — Symcon :: Automation Software
It has a fixed IP-Adress and is working fine in IP-Symcon. But now I want to change to HA. I can only tell you the IP-Adresse and the Port (5000) without SSL. Giving HA this information leads to “Connection failed”.
Hi Sir, any idea? Could you look at the page I posted and what kind of device this is?
Solved by moving my 1-Wire Installation to Shelly Plus Uni. :slight_smile:
