I want to control a WS2805 based light strip with home assistant. They are RGBCCT devices, which means RGB + 2 white LEDs (warm+cold)
Typical way to integrate light strips are esphome or wled running on a ESP device.
After some research I figured out:
- ESPhome is not able to handle a 2nd white channel at all.
- WLED is able to handle the WS2805.
For WLED, there is a RGB circle, birghtness for RGB, CCT and a color temperature for the white channel. These controls are also visible in Home Assistant. So far, so good. Unfortunately, they don’t work the right way. When a change is done, e.g. set RGB to red, the light turns red. Now the point in the RGB circle jumps back to the original value. When I reduce RGB brightness to 0%, RGB goes off but the slider jumps back to the old value (100%). Now, when CCT brightness is increased from 0% to 100%, RBB is also turned on, because in home assistant, the old value is still used. CCT brightness jumps back to 0%.
So both, ESPhome and WLED are both not really useable.
Is anyone of you using WS2805 LEDs?
Which setup are you using?
