I have a heater in my workshop (1.3kW) which is controlled by a Sonoff Power R2 switch . The Switch is named sensor.sonoff_workshop_heater. I use the power entity {sensor.sonoff_workshop_heater_power) in a ‘integration - Riemann sum integral’ Helper to create ‘Workshop Heater Consumption’ in kWh. The heater is switched on and off using an automation that monitors the temperature in the workshop. Normally, when switched on it stays on for approx 30min.
The issue I have is that as soon as the heater switches on the kWh consumption increases by approx 5kWh. It then continues to increase as expected based upon the 1.3kWh load over the next 30 mins. Obviously this initial large increase in consumption is totally incorrect but I dont know why it is happening. See image.
Does anyone have any ideas why this is happening but more to the point on how to solve it
The Boffin
