Integration sensor issue (core/homeassistant/components/integration/)
Dear All,
As you know HA provides built in integrator for those, who need to derrive an integral of some value for some purpose. However I cannot figure out how to set integration limits using this thing. No matter what I do it starts integrating fom now to infinity. Let start with zero approximation code to understand the direction to advance to, here is an example:
  - platform: integration
    source: sensor.engineering_filtered_temp_gas_heater_1
    unit_time: min
does anyone know what needs to be done to tell this thing to start integrate at T1 and stop at T2?
There is no option to set the limits of a definite integration.
That’s awfull, this thing growth to infinity than, what’s the point of having this? How can it be used?
It’s used to convert power to energy sensors (or flow to volume, etc…). If you want a fixed period of time to record the energy then feed it to a utility meter with the required cycle length (15m to yearly):
Actually, I need to integrate with arbitrary interval into the history to determiny the minimal state of the ‘action’ as it would give the optimal set of parameters for heat production to consume smallest amount of fuel (gas). Thus fixed interval is not quet what I need…
