There is no such setting available. Not for the battery, not for the inverter.
They have a bit more going on than that. Their figure is correct even if the battery is partially charged from grid with cheap energy, the formula would add that energy to pv yield.
I’ve tried using the FusinSolar kiosk with another integration but it only seems to update the kiosk page every 30 minutes and it’s figures are somehow slightly different to the main FusionSolar page too!
Anyone else seeing efficiency going above 100% at the end of the day? Could of course rename this and create filtered entity but…
I’ve got the same. When I was using Emilv2 integration I had template sensor and I was filtering this values. Now when it is in separate entity, I don’t want to create second entity.
Just checking back to share, and hopefully get some feedback, on my algorithm for setting battery paramters.
I am using appDeamon to calculate a factor that will trigger HA automations. If the calculated factor is >= 1 then battery charge from grid is made available and if the factor is < 1 it allows for discharge.
Any questions/comments are welcome, the unittests in repo is probalby a good read to understand the usage.
Hi Guys, I’m using this integration for a while through WiFi -but readings are inconsistent (some values are zeros). I was wondering, as my Inverter is 30meters away i installed AP station and have now inverter connected via LAN on 192.168.200.1 IP address, my normal network pule is 192.168.8.x, can i use second LAN card (TP-Link USB) and connect this network to HA? I have it installed on PROXMOX?
Got it working! I have to setup CPE Bridge on Mikrotik Router (mAP) required config it attached…as address in integration you have to use bottom address (in my case 192.168.8.55)
off topic. what kind of graph card you’ve used for inverter/battery state?
I was also very curious about those graphs, and figured out that these are ApexCharts.
My config:
type: custom:apexcharts-card
header:
show: true
title: Power
show_states: true
colorize_states: true
all_series_config:
type: area
opacity: 0.1
stroke_width: 1
group_by:
func: last
duration: 5m
series:
- entity: sensor.input_power
color: lightgreen
- entity: sensor.active_power
color: blue
- entity: sensor.charge_discharge_power
transform: return Math.max(0,x);
color: orange
name: Battery Discharge
color: '#800080'
transform: return -Math.min(0,x);
- entity: sensor.grid_active_power
color: lime
color: red
gives you:
and
header:
show: true
title: Battery Status
show_states: true
all_series_config:
type: area
opacity: 0.1
stroke_width: 1
group_by:
func: avg
duration: 15m
show:
in_header: false
series:
- entity: sensor.battery_state_of_capacity
type: line
yaxis_id: pct
opacity: 1
stroke_width: 3
group_by:
func: last
duration: 15m
show:
in_header: true
color: darkgreen
yaxis_id: watts
color: '#800080'
yaxis_id: watts
yaxis:
- id: pct
show: true
opposite: true
decimals: 0
max: 100
min: 15
- id: watts
show: true
decimals: 0
align_to: 250
gives you:
Yes, as @ligeza said it is “normal”. Efficiency of 655.35% is the read register with value 0xFFFF - It just means that the inverter is not working and efficiency is not calculated. The integration should probably just strip those values out… what you think @wlcrs ?
I’m not inclined to add such logic in the library. For me this is a bug on the inverter-side, not on the library side. I don’t want to create a precedent for having to support quirks like these, because this can get out of hand quickly, and I rather invest my time in other features like reading the optimizer data.
You can of course create template sensors yourself that fix the reading for your specific situation.
I have installed openwrt on the raspberry, I connect to the device through LAN connection from my desktop (I have disabled the master wifi on openwrt) and homeassistant get the information through LAN too. As you can see the brigde is between Wifi cliente and LAN interface. If you don’t have possibility to connect with LAN and need to use the master wifi, I think it could be poissible but increase a little more the configuration dificulty. I don’t understand very well your question about save and update configuration. I click on “save” after modified the configuration on every screen, and I saved a backup file of the router configuration after succesfully finalize the whole configuration of the reouter.
To connect your Homeassistant integration to the sun2000L you need to put into the integration as host the IP (LAN IP) of the openwrt router and the port according your configuration for port forwarding in openwrt router.
Continuing the discussion from Integration Solar inverter huawei 2000L:
Hi all!
I am a new user on this forum…So please dont be ungry because i can not read this long forum
So I have a Huawei Solar 8ktl-m1 inverter and it is connecting to the net via ethernet.
The droid app and the huawei website is working and i can monitor the datas.
But!
I can not read the datas with HA I configured the inverter and i set the modbus to rs485 but i can not connect ot iverter.
Plase help me! I can ping the inverter but i can not read the datas just only in the app.
what is my mistake ?
how can i set the inverter ? please give me informaton step by step …
just only in the settings! I can login into the inverter setup.
I read somewhere that i can read the datas only just one app… It is true?
thank you very much to everybody
What firmware version do you have in smart dongle? For me the best is 123 because it has opened port for LAN. In newer firmware you have to set permission in inverter settings to connect to smart dongle. With lan cable you should set slave=1 and port 502 (with newest firmware you can try 6607 and sometimes slave may be a higher number, probably it is written somewhere in the inverter settings ).
Only one connection is possible to smart dongle to read data, but app on phone is not connected directly to inverter but read statistics from internet. So with right firmware and correct settings it should work.
Now looks like the firmware version of my dongle i:V100R001C00SPC119
Than is it not good for me?
Now here is night… So tomorrow moorning i will try to update te dongle.
Can i do it in the setup of the inverte? With android app?
Thx
Regards
You can change to unrestricted and then it should work on current firmware.
Moorning
So I can not see the dongle update in the inverter setup…
The modbus is enable ( unrestricted) and now?
Now looks like i do something wrong.
I put information in to configuration yaml
Nothing
I see the sensor but no information
Please help me…
Thx
modbus:
- name: Solar
type: tcp
host: 192.168.1.195
port: 502 - name: RS485
type: serial
baudrate: 9600
bytesize: 8
method: rtu
parity: N
port: /dev/ttyUSB0
stopbits: 1
delay: 5
timeout: 3
sensor solar:
platform: huawei_solar
host: 192.168.1.195
port: 502
optimizers: false
battery: false -
platform: template
sensors:
pv_input_power:
friendly_name: “Solar Production”
#entity_id: sensor.sun2000_8ktl_m1
unit_of_measurement: ‘W’
icon_template: mdi:solar-power
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘input_power’) }}” -
platform: template
sensors:
pv_daily_yield:
friendly_name: “Daily Yield”
#entity_id: sensor.sun200í0_8ktl_m1
unit_of_measurement: ‘kWh’
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘daily_yield’) }}” -
platform: template
sensors:
pv_total_yield:
friendly_name: “Total Yield”
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘total_yield’) }}” -
platform: template
sensors:
pv_string_01_voltage:
friendly_name: “Pv String 01 Voltage”
unit_of_measurement: ‘V’
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘pv_string_01_voltage’) }}” -
platform: template
sensors:
pv_string_01_current:
friendly_name: “PV String 01 Current”
unit_of_measurement: ‘A’
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘pv_string_01_current’) }}” -
platform: template
sensors:
pv_string_02_voltage:
friendly_name: “PV String 02 Voltage”
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘pv_string_02_voltage’) }}” -
platform: template
sensors:
pv_string_02_current:
friendly_name: “PV String 02 Current”
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘pv_string_02_current’) }}” -
platform: template
sensors:
pv_active_power:
friendly_name: “Power Meter Active Power”
unit_of_measurement: ‘kW’
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘power_meter_active_power’) }}” -
platform: template
sensors:
consumption:
friendly_name: “Consumption”
value_template: ‘{{ states(“sensor.sun2000_8ktl_m1”) |float - states(“sensor.pv_active_power”) | float }}’ -
platform: template
sensors:
pv_device_status:
friendly_name: “Device Status”
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘device_status’) }}” -
platform: template
sensors:
pv_string_02_power:
friendly_name: “PV String 02 Power”
value_template: ‘{{ states(“sensor.pv_string_02_voltage”) |float * states(“sensor.pv_string_02_current”) | float / 1000|round(2) }}’ -
platform: template
sensors:
pv_string_01_power:
friendly_name: “PV String 01 Power”
value_template: ‘{{ states(“sensor.pv_string_01_voltage”) |float * states(“sensor.pv_string_01_current”) | float / 1000|round(2) }}’ -
platform: template
sensors:
pv_efficiency:
friendly_name: “Solar Efficiency”
unit_of_measurement: ‘%’
value_template: “{{ state_attr(‘sensor.sun2000_8ktl_m1’, ‘efficiency’) }}”
You doing it wrong. You can’t use two different integration to connect to smart dongle because it is only one connection possible at the time. As I said before you have to add in config slave=1 (or sometimes it could be other number ).
I suggest you to delete all this config you posted and use this integration:
On this site you have manual how to install it. Try port 502 and slave=1
Hi
I did it many times
here is te resault:
2022-03-13 07:31:42 ERROR (SyncWorker_0) [pymodbus.client.sync] Connection to (192.168.1.195, 502) failed: [Errno 111] Connection refused
2022-03-13 07:31:46 ERROR (MainThread) [homeassistant.components.sensor] The huawei_solar platform for the sensor integration does not support platform setup. Please remove it from your config.
Now?
I dontn know
Hello farkas16,
Try with this first. If it works you can add more sensors (or the integration) :
Use port 6607 or 502. But actually you should connect to the Inverter AP and use 192.168.200.1.
# Modbus
modbus:
type: tcp
host: 192.168.1.195
port: 6607
delay: 10
close_comm_on_error: true
retry_on_empty: true
retries: 10
sensors:
- name: Input Power
device_class: power
unit_of_measurement: kW
count: 2
address: 32064
data_type: int32
scale: 0.001
precision: 3
PS:
- If you use the Inverter AP, make sure nothing else (eg APP Phone) is connected to it
- To update dongle with the APP, you need to connect to the Dongle AP directly with the phone.
When you unplug the Dongle from the Inverter (usb) and plug it back in (after 1 min), it will broadcast its SSID for a while. Connect to it with the APP (scan QR-code or manually select) and update.
Thx…
Not work…
I try to update the dongle… I see the update but now can you send me a link where is the latest or working firmware?
Thank you so much
