[Integration] Somfy venetian blinds using RFXCOM RFXtrx
I’ve been working on extending the standard RFXCOM RFXrtx Somfy support to have better functionality with venetian blinds. Basically I wanted better tilt and lift support than the out-of-the-box versions give. I’ve also added support for Louvolite Vogue vertical blinds.
If you’re using the same hardware as I do then you might find it useful. I’d be grateful for any feedback.
Adding stateful tilt operations to Somfy Venetian blinds
very interesting !
but not working on 2023.9.2
please update the integration
thanks!
