I am a newbee in HomeAssistant.
I don’t know many things about it and still learning.
Normaly i was working with Domoticz (what was working fine) but now i cannot make a bridge working in it and the support is minimum.
SO i decided to take a shot with homeassistant.
Al my lightswitches are already working fine in hommeass.
Now i have a (they called it )hacked toon.
If you start it it say’s toon with hacked through the letters.
This i could use inside domoticz perfect without eneco.(It is still running in domoticz at this moment)
Before i start to play with the rf bridge from sonoff with tasmota on it i want to see if i can make the toon working also in home assistant like in domoticz.
So i read some things but everything is based on the subscription from eneco. (if i am right)
Is there anyone who has it working with a toon as i have?
Thank you, i believe that is the thing i need.
But i need to make the climate/toon.py.
Can i make this file in an ssh sesion?
I cannot login by ssh.
If i put the sd card into the computer i cannot see the files.
I need to format the card it says.
So please i need a little help in this.
After one evening busy with making toon working i give up for now.
I even have no clue where to put the toon.py
Also no clue how to come there.
In homeassistant configurator i can go to many directory’s but nowhere a folder named homeassistant.
I am not a programmer so many things are abracadabra.
I only copy and paste stuf what i find to make it in my home working.
I managed to do it in domoticz and i was hoping i could figure it out to do it in homeassistant.
If i have this working i can go further to see if i can make the rf bridge working but this has prioraty.
If somobody who doesn’t matter can help me to make this work?
Thank you, but in the webconfigurator i cannot find the custom_components.
So where do i make this folder , because i cannot find the folder homeassistant either.
Where do i create the folders in the web configurator?
Ok after again good reading i have the sleep, comfort section working.
The smart-meter says niet bekend so not available.
But we are on the good way.
I want to thank the people here for the quick response.
Now i have seen the toon is working i am going to try tomorrow to use the rf bridge.
If this is working then homeassistant has won it from domoticz for me.
I am busy long time to make this working and in the forum i don’t get many response.
Only 1 person anser me but that takes some time.
Here i got the same evening response and voila it is working for some parts already.
Yes there is Sensor: above.
I don’t know where tpo look.
Can you please write me exactly what and where to put it.
The part what does the temperature is working.
Only this part not.
