Integration Waze on an iPad, issue with reCAPTCHA
My integration of Waze works perfectly.
However, recently (after one of the upgrades of HA) it doesn’t work on an iPad anymore.
At the bottom left you see the message about a supported browser to get a reCAPTCHA challenge. Does anybody know what to do to solve this issue?
I have seen issues with live camera stream as well on an iPad. On a Mac with Safari everything runs fine, switching to iPad there is an issue… What kind of browser does HA use within the HA app on an iPad?
Hi, are you using safari or the companion app?
On other platforms the companion app uses webview but I don’t know if this is the same for iOS
I use ‎Home Assistant on the App Store for the iPad (or iPhone). I have just updated the app, but there is no difference.
From Waze Travel Time - Home Assistant
Are you using the right URL?
I guess the reCAPTCHA is normal and you have to confirm and I don’t know if the mobile app is able to do this.
Have you tried to open in safari on the tablet?
Yes, I’m using similar… I’ve just copied the one I’m using: [Preformatted text](https://embed.waze.com/iframe?zoom=12&lat=52.357361&lon=4.720345&ct=livemap)
I have tested it by copying it into Safari and the result is that all is working fine. So, the issue is HA and its own browser. No idea, what is being used for an iframe in HA…
