Intel NUC based install wont start after 9.0 Update
Known issue or just me?
Update seemed to go fine, running no problems last night, just had to turn the power off and after rebooting cannot connect to HA any more :frowning:
Need to lug a monitor down to the living room now and try and see what is displaying on the screen.
Weird…working now…several reboots later its finally come up
And broken again after a shutdown ……5th reboot
Can I downgrade the OS ver to previous as this is horrible
Hi Andy,
have you solved the issue? I am in the same situation and my NUC rebooting itself without connecting to home assistant OS.
The SSD seams to be fine.
Let me know if you have found a solution
Hey…it’s been stable for a while ( as In I havnt rebooted it since it came up successfully! Not a coward at all :wink: )
As soon as I get half an hour to mess around with it ill try another reboot
Hi, same problem here. Anyone has found a solution?
