Required materials
KOB electronic lock
Relay
MFRC522 module
Realized function
- card registration.
- username and password registration.
- card swipe to unlock the electronic lock.
- User name and password to unlock the electronic lock.
Connection diagram
Code sharing
import mfrc522
import time
import _thread
from os import uname
from machine import Pin, UART
#from pyb import UART
#import machine
suos = Pin(32,Pin.OUT)
uart2 = UART(2, baudrate=115200, rx=16,tx=17,timeout=10)
ESP32_HSPI_CLOCK = 14
ESP32_HSPI_SLAVE_SELECT = 15
ESP32_HSPI_MISO = 12
ESP32_HSPI_MOSI = 13
ESP32_MFRC522_RST = 5
rx3 = []
rx_name = []
user_id_flag = False
password_flag = False
temp_id = ''
temp_mima = ''
personnel_id = {'zbw':[236,230,169,47],'lbw':[19,165,93,4]}
personnel_ps = {'zbw':'zbw3366','lbw':'lbwnb'}
admin_password = ('yyds')
button_cmd = [16,1]
edit1_cmd = [16,112]
edit2_cmd = [16,113]
edit3_cmd = [16,114]
if uname()[0] == 'esp32':
rdr = mfrc522.MFRC522(ESP32_HSPI_CLOCK, ESP32_HSPI_MOSI, ESP32_HSPI_MISO, ESP32_MFRC522_RST, ESP32_HSPI_SLAVE_SELECT)
def do_write():
try:
(stat, tag_type) = rdr.request(rdr.REQIDL)
if stat == rdr.OK:
(stat, raw_uid) = rdr.anticoll()
if stat == rdr.OK:
print("New card detected")
print(" - tag type: 0x%02x" % tag_type)
print(" - uid : 0x%02x%02x%02x%02x" % (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3]))
print("")
if rdr.select_tag(raw_uid) == rdr.OK:
key = [0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF]
if rdr.auth(rdr.AUTHENT1A, 8, key, raw_uid) == rdr.OK:
stat = rdr.write(8, b"\x00\x53\x00\x54\x00\x4F\x00\x4E\x00\x45\x0a\x0b\x0c\x0d\x0e\x0f")
rdr.stop_crypto1()
if stat == rdr.OK:
print("Data written to card")
else:
print("Failed to write data to card")
else:
print("Authentication error")
else:
print("Failed to select tag")
except KeyboardInterrupt:
print("write error")
def do_read():
while True:
try:
if stat == rdr.OK:
if stat == rdr.OK:
print (raw_uid[0], raw_uid[1], raw_uid[2], raw_uid[3])
print("")
print("Address 8 data: %s" % rdr.read(8))
for ps in personnel_id:
if raw_uid[0:4:1] == personnel_id.get(ps):
suos.value(1)
print(ps)
uart_write(ps, *raw_uid[0:4:1])
time.sleep(3)
uart2.sendbreak()
break
rdr.stop_crypto1()
time.sleep(3)
suos.value(0)
else:
else:
if uart2.any()>1:
rx2 = []
data_name2 = ''
bin_data = uart2.read(40)
uart2.sendbreak()
rx1 = list(bin_data)
for item in rx1:
rx2.append(chr(item))
print(rx2)
if rx1[3:5:1] == button_cmd:
data_name_len = rx1[6] - 1
data_name = rx2[7:data_name_len+7:1]
data_name2 = ''.join(data_name)
print(data_name2)
if data_name2 == 'back3':
return
print("read error")
def do_read2 (idd):
print(idd)
while True:
try:
if stat == rdr.OK:
if stat == rdr.OK:
print("")
personnel_id[idd] = raw_uid[0:4:1]
uart_write3(*raw_uid[0:4:1])
rdr.stop_crypto1()
else:
else:
if uart2.any()>1:
rx2 = []
data_name2 = ''
uart2.sendbreak()
for item in rx1:
print(data_name2)
if data_name2 == 'back1':
return
print("read error")
def uart_write(text, *ids):
# print(text, *ids)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"'+str(text)+'"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"'+str(ids)+'"}>ET')
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":true}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardname1","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid1","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock1","visible":false}>ET')
def uart_write2(text,text2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text+'"}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+text2+'"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit2","text":"''"}>ET')
def uart_write3(*id2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"'+str(id2)+'"}>ET')
time.sleep(3)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"cardid","text":"''"}>ET')
def uart_write4(text,text2):
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text+'"}>ET')
time.sleep(1)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"login","text":"'+text2+'"}>ET')
time.sleep(1)
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit3","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit4","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit7","text":"''"}>ET')
def uart_write5():
time.sleep(3)
def card_zhuce():
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
data_end = rx_num-5
data_id_st = rx2[8:13:1]
data_id_st2 = ''.join(data_id_st)
print(data_id_st2)
if data_id_st2 == 'edit1':
data_id_st3 = rx2[15:data_end:1]
data_id_st4 = ''.join(data_id_st3)
print(data_id_st4)
if data_id_st4 != '':
name = True
elif data_id_st2 == 'edit2':
data_id_st5 = rx2[15:data_end:1]
data_id_st6 = ''.join(data_id_st5)
if data_id_st6 == admin_password:
admin = True
uart_write2('Verification passed!','Please place the card!')
do_read2(data_id_st4)
return
def mima_zuce():
temp_id3 = ''
temp_mima3 = ''
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
# data_end = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
# if (rx2[rx_num] == 'T') and (rx2[rx_num-1] == 'E') and (rx2[rx_num-2] == '>'):
# break
data_end = rx_num-5
print(data_id_st2)
print(data_name2)
if data_name2 == 'back2':
return
if data_id_st2 == 'edit3':
print(data_id_st4)
user_id_flag = True
temp_id3 = data_id_st4
# personnel_ps[temp_id] = raw_uid[0:4:1]
elif data_id_st2 == 'edit4':
print(data_id_st6)
# if personnel_ps.get(temp_id) == data_id_st6:
password_flag = True
temp_mima3 = data_id_st6
# personnel_ps[temp_id] = password_flag
# print(rx2,user_id_flag,password_flag)
elif data_id_st2 == 'edit7':
if (data_id_st6 == admin_password) and (password_flag == True) and (user_id_flag == True):
admin = True
personnel_ps[temp_id3] = temp_mima3
uart_write4('Verification passed!','login was successful!')
def password_loin():
temp_id2 = ''
temp_mima = ''
while True:
if uart2.any():
user_id = ''
password = ''
rx2 = []
rx_num = 0
# data_end = 0
uart2.sendbreak()
for item in rx1:
rx_num += 1
# break
data_end = rx_num-5
print(data_id_st2)
print(data_name2)
if data_name2 == 'back4':
return
if data_id_st2 == 'edit5':
print(data_id_st4)
if data_id_st4 in personnel_ps:
user_id_flag = True
temp_id2 = data_id_st4
elif data_id_st2 == 'edit6':
print(data_id_st6)
print(temp_id2)
print(personnel_ps)
if personnel_ps.get(temp_id2) == data_id_st6:
print(user_id_flag,password_flag)
if (password_flag == True) and (user_id_flag == True):
uart_write(temp_id2,temp_id2)
suos.value(1)
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":true}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit5","text":"''"}>ET')
uart2.write('ST<{"cmd_code":"set_text","type":"label","widget":"edit6","text":"''"}>ET')
time.sleep(3)
# uart_write('student','')
suos.value(0)
uart2.write('ST<{"cmd_code":"set_visible","type":"widget","widget":"lock2","visible":false}>ET')
uart2.sendbreak()
while True:
if uart2.any()>1:
rx2 = []
data_name2 = ''
# time.sleep(1)
uart2.sendbreak()
# time.sleep(1)
for item in rx1:
print(rx2)
print(data_name2)
if data_name2 == 'card1':
card_zhuce()
elif data_name2 == 'password1':
mima_zuce()
elif data_name2 == 'card2':
do_read()
elif data_name2 == 'password2':
password_loin()
