Intent script problem
I created intent_script.yaml and in configuration.yaml I included intent_script: !include intent_script.yaml and after I moved my intent scripts there there, my custom sentences no longer work. When I try to use the voice assistant, I get the following response “unexpected error during intent recognition”. Before moving to intent_script.yaml everything worked normally… Did I miss something or it simply works only if intent scripts are in configuration.yaml.
Did you remove the intent_script: line from the intent_script.yaml file?
Post the relevant snippets from configuration.yaml and intent_script.yaml so that we can have a look.
:man_facepalming: I didn’t. That was the problem. Thanks for the tip!
