Intent targets to intent_script
Hi, I have intent:
  testovaciIntent:
      - sentences:
          - "Testovací intent <area>"
        slots:
          domain: light
If I debug this intent:
I have intent_script:
  testovaciIntent:
      - action: persistent_notification.create
          message: **Targets entity**
I need works with targets in actions. Is it possible please?
{area} is a variable that is in expansion rule <area>
You can use it to create an entity filter
{{ states.light |selectattr('entity_id', 'in', area_entities(area)) |map(attribute='entity_id') |list }}
Thank you… the problem is that “area” can also be an alias for area.
Yes it’s a problem, it was discussed just today
If you have a desire, you can create an issue on github to remind about the problem.
You can use the dictionary in your intent scripts until this is fixed.
you have to define the dict first
    {% set area_alt = area %}
    {% set areadict = {
        "alias1_area1": "area1",
        "alias2_area1": "area1",
        "alias1_area2": "area2",
        "alias1_area3": "area3",
        "alias1_area4": "area4"
After that, you can use this condition
area_entities( areadict[area_alt] if area_alt in areadict else area)
