Hi all,
Posting here to document my attempts to resolve this issue, hopefully it can help other users with a similar issue. Thanks to mods who have helped me get this far.
I have a fresh install of HA that I cannot access through the browser by any method. It is listed as a wired (LAN) connection in my router UI and responds to pings, but that is all. I have tried:
- 15-20 re-flashes
- several re-downloads of 32bit and 64 bit images
- several power supplies
- several SD cards
- several SD card readers
- wifi and LAN install attempts
- specifically allowing TCP traffic to port 8123 as per this guide
- disabling windows firewall altogether
Debugging using this guide yielded the following report:
-- Logs begin at Fri 2018-06-22 11:11:49 UTC. --
Jun 22 11:47:10 hassio hassos-supervisor[552]: 18-06-22 11:47:10 WARNING (MainThread) [hassio.homeassistant] Fails install landingpage, retry after 30sec
Jun 22 11:47:40 hassio hassos-supervisor[552]: 18-06-22 11:47:40 INFO (SyncWorker_11) [hassio.docker.interface] Pull image homeassistant/raspberrypi3-homeassistant tag landingpage.
Jun 22 11:47:50 hassio hassos-supervisor[552]: 18-06-22 11:47:50 ERROR (SyncWorker_11) [hassio.docker.interface] Can't install homeassistant/raspberrypi3-homeassistant:landingpage -> 500 Server Error: Internal Server Error ("Get https://registry-1.docker.io/v2/: dial tcp: lookup registry-1.docker.io on 192.168.1.1:53: read udp 192.168.1.103:42324->192.168.1.1:53: i/o timeout").
Would appreciate some pointers from more experienced folks. I’ve had HA working in the past and it seemed great, but I’m not sure I want to automate my whole life on something that breaks on a fresh install…
