Hey,
I had Hass.io up and running on my Pi with no problems but for some reason it has now stopped working…
So i have installed the following add-ons that all still work
- Samba Share
- Mosquitto broker
- Configurator
I’m connected with an ethernet cable directly to my router.
I had Home Assistant cloud working with along with weather updates from YR. I can no longer login to Home Assistant cloud, get weather updates or get updates from home assistant. So i was thinking that my Pi had lost internet connection. But for some reason i can still download new add-ons from the add-on store?
I get the following errors from my logs
2019-03-31 07:10:51 ERROR (MainThread) [homeassistant.components.sensor.yr] Retrying in 19 minutes: Cannot connect to host aa015h6buqvih86i1.api.met.no:443 ssl:None [Try again]
2019-03-31 01:10:43 ERROR (MainThread) [homeassistant.components.updater] Could not contact Home Assistant Update to check for updates
The Home assistant IP-adress and my sonoff tasmota switch are reserved on my router
Any ideas on what could be wrong? How do i check if im connected to the internet?
Cheers!
