First of all, I want to say thank you to all the folks that actively answer and help on this community. I have learned a lot and solved many issues by reading existing posts. I am new to HA, (less than 2 months) but achieved many of my goals with HA.
Now it happens to be different, since I am not able to make IntesisHome integration work.
I am on 2020.12.1 version, Host is Home Assistant OS 5.9.
I added in configuration.yaml
this entry, using my real username and pass (which work perfectly in Intesis mobile app:
climate:
- platform: intesishome
username: YOUR_USERNAME
password: YOUR_PASSWORD
The error I get is:
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 199, in _async_setup_platform
await asyncio.shield(task)
File "/usr/src/homeassistant/homeassistant/components/intesishome/climate.py", line 117, in async_setup_platform
File "/usr/src/homeassistant/homeassistant/components/intesishome/climate.py", line 118, in <listcomp>
IntesisAC(ih_device_id, device, controller)
File "/usr/src/homeassistant/homeassistant/components/intesishome/climate.py", line 179, in __init__
self._fan_modes = controller.get_fan_speed_list(ih_device_id)
File "/usr/local/lib/python3.8/site-packages/pyintesishome/pyintesishome.py", line 705, in get_fan_speed_list
return list(config_fan_map.values())
AttributeError: 'int' object has no attribute 'values'
My AC is a Fujitsu ACY 100K-KA, with 5 modes enabled (cool, heat, dry, auto, fan only) and 6 fan speeds plus auto fan.
Is there something I miss or, indeed, there is a real issue with this integration?
Cheers,
