Introduction and advice
Hi all.
Just want to introduce myself and start getting advice on starting down the road of Home Automation and have decided to use Home Assistant to manage it all.
Name is Des and I’m in South Africa. I have a few Sonoff switches and a Tuya Sprinkler system. I am doing some house alterations currently and will be installing a Home Assistant Green.
What are some of the biggest pitfalls to avoid? And simplest and most effective must-do items?
Des
Welcome.
You should start here: 20 things I wished I knew when I started with Home Assistant. Which is a subtopic of this: The Home Assistant Cookbook - Index.
Thanks. I’ll get started there.
Des
