Invalid Automation config?
Hello!
The webui says Invalid Config (automation), but in ssh command hass --script check_config is all green… Multiple online yaml checker says all OK. How to check what is wrong with the automation config?
What does the log say?
Beware that yaml checkers only check if it is valid yaml, and not that it is valid configuration.
The webui panel was just stuck… Dismissed it and after service restart its all OK. Thanks tho.
