anyone know what is happening in here? updated to latest(0.115.2) version and getting this.
it did not show which line the error is coming from
maybe anyone here experiencing the same can help?
I also have this error, it actually comes from the HASP packages files, probably a version change from the templating engine of Home Assistant broke the automation, but fear not the solution is easy. You’ll see on the file hasp_home_cinema_p8_media.yaml that there’s a template line with two single quotes before each variable. You just have to remove one of them. Here’s a before and after image to make the explanation more clear:
Before:
