I keep getting this error to show up in my logs when I login to my home-assistant interface.
Logger: homeassistant.config
Source: config.py:455
First occurred: 5:01:34 AM (3 occurrences)
Last logged: 5:01:34 AM
Invalid config for [automation]: Device d29bdbe7b10a01c7afdccf52b46ada35 not found. Got OrderedDict([('default_config', {}), ('tts', [OrderedDict([('platform', 'google_translate')])]), ('group', {}), ('automation', [OrderedDict([('id', '1602285939712'), ('alias', 'iPad Charging Off'), ('description', ''), ('trigger', [OrderedDict([('type', 'battery_level'), ('platform', 'device'), ('device_id', 'b34927670e0111ebaaf703660a102806'), ('entity_id', 'sensor.tcochrans_ipad_battery_level'), ('domain', 'sensor'), ('above', 99), ('below', 101)])]), ('condition', []), ('action', [OrderedD.... (See /config/configuration.yaml, line 13).
It keeps referencing this line in the code
I am not entirely sure what good be causing this issue. The only thing this automation does is turn off tp-link switch when my iPad gets to 100%. I am not sure is something in a more recent update broke or if it is trying to find something not being used. When I look at the yaml I am not seeing what could be causing it. Yaml is posted below, though I primarily do all my automations in the visual UI.
alias: iPad Charging Off
description: ""
- type: battery_level
platform: device
device_id: b34927670e0111ebaaf703660a102806
entity_id: sensor.tcochrans_ipad_battery_level
domain: sensor
above: 99
below: 101
condition: []
- type: turn_off
device_id: 08601de036894d3fd894234dbb6c8178
entity_id: switch.tool_charger
domain: switch
- service: notify.mobile_app_galaxy_s10_device
title: Charging
message: iPad Charged
mode: single
