Invalid config for cloud when I add google_actions
I have a cloud config that works perfectly fine for Alexa, but when I try to implement the Google version I get “invalid config” in the logs and the cloud component won’t start. I cannot figure out what I’m doing wrong. Here’s the config:
alexa:
  filter:
    include_domains:
      - light
      - switch
    include_entities:
      - script.night
      - script.xbox
      - group.basement_lights
      - group.kitchen_lights
      - group.bar_lights
      - group.playroom_lights
      - scene.basement_high
      - scene.basement_medium
      - scene.basement_low
      - scene.basement_movie
    exclude_entities:
      - scene.all_bright
      - switch.basementmaster_switch
      - light.basementhallslave_level
      - switch.basementhallslave_switch
  entity_config:
    script.night:
      description: A script to enable night mode
    light.kitchenmainlights_level:
      name: Main kitchen lights
    light.familyroommainlights_level:
      name: Main family room lights
    light.fireplacelights_level:
    light.foyerlights_level:
    scene.basement_movie:
google_actions:
  filter:
    include_domains:
      - light
      - switch
    include_entities:
      - script.night
      - script.xbox
      - group.bar_lights
    exclude_entities:
      - scene.all_bright
  entity_config:
    script.night:
If I comment out the whole google_actions: section, the alexa part works fine.
what’s the error?
Also, I notice that you just copied and pasted your config but I’m guessing you never checked the docs?
Google assistant via clouds does not accept ‘description’ as an attribute for entity configurations.
entity_config
(map)(Optional)Entity specific configuration for Google Assistant.
<ENTITY_ID>
(map)(Optional)Entity to configure
name
(string)(Optional)Name of entity to show in Google Assistant.
aliases
(list)(Optional)Aliases that can also be used to refer to this entity.
room
(string)(Optional)Hint for Google Assistant in which room this entity is.
Ah! Description. Dammit.
I did check the docs. I’ve been staring at the docs for a very long time, trying to figure out what I’m missing. But I was focused on things that should have been there rather than shouldn’t have been there…yes, I copy/pasted initially. Thanks!
It’s always good to have a second set of eyes!
