Hello all! Already spent some hours trying to figure this out. I created a self signed wildcard certificate for my local domain. I don’t expose HA to the outside world but use a VPN instead.
The self signed certificate already worked for my Proxmox installation, now it’s HTTPS.
So I wanted the same with HA. But I keep getting this error:
Invalid config for [http]: not a file for dictionary value @ data[‘http’][‘ssl_key’]. Got ‘/config/ssl/cert_key.pem’. (See /config/configuration.yaml, line 17).
I found several posts on the web, with several solutions but so far none worked for me. I changed the file permissions (now 755 so that shouldn’t be an issue anymore).
Tried moving the cert and key (both .pem files) to a different folder. Changed my configuration.yaml, checked indentation which seems to be good now.
Moved the files from the SSL folder to the config folder and back. Changed permissions again.
Read the documentation. I seem to be out of options for now.
I’m using HassOS 7.5 HA version is currently 2022.3.7.
My configuration.yaml currently looks like this:
http:
ssl_certificate: /config/ssl/cert.pem
ssl_key: /config/ssl/cert_key.pem
I get the error when checking the config (in ‘validate configuration’).
Didn’t yet try to ignore the warning and see if it works. I think this is something that can be approved in HA in the future.
