I’m literally pulling my hair out now so need to ask for help.
Today I upgraded to 0.117.5, running Home Assistant OS (HassOS 4.15) via Proxmox on an NUC. Been working great for a long time and upgraded for the Xbox integration with the new Xbox coming out yesterday.
For some reason HA refuses to recognise the scripts line in configuration.yaml with the following error message:
Logger: homeassistant.config
Source: config.py:415
First occurred: 2:02:32 (3 occurrences)
Last logged: 2:02:32Invalid config for [script]: Integration ‘’ not found (See /config/configuration.yaml, line 10).
My config which worked before and comes back as valid config in server controls is as follows (Also with an empty scripts.yaml file):
homeassistant:
customize: !include customize.yaml
script: !include scripts.yaml
group: !include groups.yaml
scene: !include scenes.yaml
notify: !include notifications.yaml
When I try to create a script anyway I get the following error message:
Message malformed: Integration ‘’ not found
I’ve rolled back via a snapshot with the same config file and scripts work correctly.
Really do not know what to do, unfortunately I’m not a coder but have managed tog et through researching the best I can and reading the forums but this doesn’t seem to be a common problem so would be really appreciative if anyone could help.
Thank you.
