I had everything configured untill today, when I updated esphome.
After that the problem has stared.
I see in the notification tab:
Error doing job: Task exception was never retrieved
13:27:50 – (ERRORE) components/hassio/__init__.py
Can't read add-on info:
13:24:19 – (ERRORE) hassio - il messaggio si è verificato per la prima volta alle 13:24:19 e compare 2 volte
Timeout on /addons/5c53de3b_esphome/info request
Setup failed for raspberry_pi: (DependencyError(...), 'Could not setup dependencies: hassio')
13:22:54 – (ERRORE) setup.py
Unable to set up dependencies of raspberry_pi. Setup failed for dependencies: hassio
Error during setup of component hassio
13:22:50 – (ERRORE) components/hassio/handler.py
Can't read panel info: System is not ready with state: setup
13:22:50 – (ERRORE) hassio
Can't read Supervisor data: System is not ready with state: setup
13:22:50 – (AVVISO) hassio
Not connected with the supervisor / system too busy!
13:22:49 – (AVVISO) hassio
And:
All the addons are desappear. Is like the Supervisor is not loaded.
Does anybody have an idea of I can fix this?
Thank you!
