I currently have a working https lan connection however I am getting the infamous:
Invalid local network URL
You have configured an HTTPS certificate in Home Assistant. This means that your internal URL needs to be set to a domain covered by the certficate.
my certificate was created using mkcerts
with the following:
mkcert -key-file key.pem -cert-file cert.pem home.lan
here is my config file:
http:
ssl_certificate: ./ssl/cert.pem
ssl_key: ./ssl/key.pem
ip_ban_enabled: true
login_attempts_threshold: 5
