Invalid slug?
Hello
I want to add a sum of inputs values in conf.yaml
Min_hysteresis and max_hysteresis but im doing something wrong?
Configuration warnings
Invalid config for ‘template’ from integration ‘sensor’ at configuration.yaml, line 115: invalid slug Min_hysteresis (try min_hysteresis) for dictionary value ‘sensors’, got {‘grid_energie_import’: {‘friendly_name’: ‘Grid energie import’, ‘unit_of_measurement’: ‘kWh’, ‘value_template’: ‘{{ states(“sensor.electricity_meter_energy_consumption_tarif_1”) |float + states(“sensor.electricity_meter_energy_consumption_tarif_2”) | float }}’}, ‘grid_energie_export’: {‘friendly_name’: ‘Grid energie export’, ‘unit_of_measurement’: ‘kWh’, ‘value_template’: '{{ states(“sensor.electricity_meter_energy_production_tarif_1”) |float + states("sensor.electricity_meter_energy_product
for EXCEL sheet and power meter"
    sensors:
        grid_energie_import:
            friendly_name: "Grid energie import"
            unit_of_measurement: 'kWh'
            value_template: '{{ states("sensor.electricity_meter_energy_consumption_tarif_1") |float + states("sensor.electricity_meter_energy_consumption_tarif_2") | float }}'
        Min_hysteresis:
           friendly_name: "Min hysteresis"
           unit_of_measurement: '°C'
           value_template: '{{ states("input_number.eurom_convector_set_temperature") |float - states("input_number.eurom_hysteresis") | float }}'
This is part of the code
    sensors:
    sensors:
        min_hysteresis:
Did you do as the error advised? Slugs should be lower case
Also why are you still using the legacy template platform?
Aah lowercase thx that is the solution
Legacy template platform?
Is there a better solution/modern way?
template:
  - sensor:
      - name: "Grid energie import"
        state: >
               {{ states("sensor.electricity_meter_energy_consumption_tarif_1") |float(0) +
                  states("sensor.electricity_meter_energy_consumption_tarif_2")|float(0) }}
  - sensor:
      - name: "Min hysteresis"
        state: >
               {{ states("input_number.eurom_convector_set_temperature")|float(0) -
                  states("input_number.eurom_hysteresis")|float(0) }}
Ok thx i will update my code
Thx again for helping me
