Hello experts,
I try to use a service but I have problems with the time-format:
If I use this, everything works fine:
service: sonos.update_alarm
alarm_id: 14
entity_id: media_player.kuche
time: 17:15:00
If I use this, the following erros occurs:
alarm_id: 14
time: '{{ states['input_datetime.wecker_individuell'].state }}'
Invalid time specified: {{ states[‘input_datetime.wecker_individuell’].state }} for dictionary value @ data[‘time’]
Can anyone help?
finity
March 24, 2021, 2:03pm
2
try fixing your quotes.
the outer quotes need to be the opposite type as the inner ones so change them to a double quote.
And you don’t need to reference the entity in that way.
so you can do it like this:
time: "{{ states.input_datetime.wecker_individuell.state }}"
or like this (recommended):
time: "{{ states('input_datetime.wecker_individuell') }}"
If neither of those work then I would assume that means that the time can’t be templated.
Unfortunately it doesnt work
Same error: Invalid time specified
finity
March 24, 2021, 2:21pm
4
Then it is probably the case that the time isn’t able to be templated.
ok, but how can I use the time from input_datetime (or any other input-objetc) in a service?
Or is it just a problem in this service (sonos.update_alarm)?
petro
(Petro)
March 24, 2021, 2:44pm
6
Does the sonos service allow the following? What happens when you use the service caller for this configuration?
alarm_id: 14
time: '00:10:00'
Yes, this works when I call the service. But I need to insert the time from the input_datetime.
petro
(Petro)
March 24, 2021, 3:18pm
8
Then what @finity wrote should work. I verified that the template returns a string, are you sure you tried his template and received the same error?
Also what version of HA are you running?
Lastly, please reply to me properly, use the reply button on my post, not the blue reply button.
finity
March 24, 2021, 3:29pm
9
If the templates I (and others) said should work but they don’t then it is likely that this service doesn’t accept a template for the time.
There are other services that accept templates for the time so it isn’t just all services in general.
That´s why I´m really confused. It seems to be pretty easy, but it doesnt work.
I tried again and copied the code. But the service only works when I insert the time directly.
If I use your code e.g. in custom-buttom card, it works. But not in this service.
petro
(Petro)
March 24, 2021, 3:42pm
11
How are you calling this service when testing the template?
Im using the service UI in the development tools
And I´m using the latest version of HA.
petro
(Petro)
March 24, 2021, 3:47pm
13
Templates don’t work in the service caller.
petro
(Petro)
March 24, 2021, 3:48pm
14
Make a script and put the script into your custom button card. It’ll work.
Really? I did not know that. I will try it. Many Thanks!
finity
March 24, 2021, 11:27pm
16
That would have been useful info from the beginning.
I assumed it was in a script/automation and didn’t work.
petro
(Petro)
March 25, 2021, 8:47am
17
That’s coming in 2021.4, so no more guessing
