[SOLVED] Invert Position Values - Zipato Micromodule Motor Controller (Philio PAN-08)
Hello!
I am pretty new to Home Assistant. Just started with a Hassio VM on Proxmox. I have an Aeotec Z-stick and added a couple of Z-Wave devices successfully. These include a Zipato Micromodule Motor Controller. This is just a slightly modified version of Philio PAN-08. This Zipato device is controlling a roller shutter. Unfortunately when setting it to 100% via Home Assistant I get a closed shutter (i.e. position values are inverted). Is there a way to fix this?
TLDR: is there an easy way to invert position values for cover and switch entities?
Thanks, Adam
Here is a solution for this specific hardware:
Page 13:
The shutter move direction is reverse
Wrong connection of NC and NO to the motor
Swap the NC NO connection
The team that installed the shutters and controllers seemed to have made a mistake. Swapping the wires solved the problem.
