Inverter Controller for Home Assistant
GitHub - MarcelWepper/Inverter-Controller
Stop using static timer-based scripts to manage your inverter limits. This integration provides reactive, event-drivenpower balancing logic that dynamically adjusts your inverter’s output based on real-time grid consumption, battery state of charge (SoC), and solar production.
Key Features
- Reactive Power Balancing: Listens for state changes and adjusts power limits instantly as your house load shifts.
- Exponential Moving Average (EMA): Built-in smoothing for solar production to prevent “flapping” during cloudy days.
- Safety Guard: Automatically forces the inverter to a safe minimum (100W) if solar production drops below a critical threshold.
- High SoC Hard Boost: Intelligent hysteresis logic that ramps up output when the battery is nearly full (>96%) to prevent energy waste.
- Advanced Statistics: Provides Estimated House Load, Solar Yield Ratio, and Logic State sensors.
- Master Switch: Includes a dashboard toggle to instantly enable or disable the logic.
Installation
1. Via HACS (Recommended)
This integration is available directly through HACS:
- Open HACS in your Home Assistant instance.
- Navigate to Integrations.
- Click Explore & Download Repositories in the bottom right.
- Search for
Inverter Controller. - Click Download, then Restart Home Assistant.
2. Manual Installation
- Download the
inverter_controllerfolder from the GitHub repository. - Copy it into your
custom_components/directory. - Restart Home Assistant.
Configuration
Once installed and restarted, go to Settings > Devices & Services > Add Integration and search for Inverter Controller.
Step 1: Mandatory Entities
- Grid Power Sensor: Net house power (Positive = Import, Negative = Export).
- Battery SoC Sensor: Current battery percentage (0-100%).
- Solar Production Sensor: Raw PV power.
- Inverter Limit Control: The
numberorinput_numberentity that sets the inverter’s maximum output.
Step 2: Fine-Tuning
- Min/Max Power: Absolute bounds (e.g., 100W - 800W).
- Step Size: Watt adjustment per cycle (e.g., 50W).
- EMA Alpha: Smoothing factor.
0.1is slow/stable,0.9is fast/reactive.
Status & Feedback
I’m looking for feedback on:
- Logic responsiveness during high-load spikes.
- EMA effectiveness in different weather.
- Any brand-specific inverter edge cases.
Check out the full documentation on GitHub!
