Hi
Is there a way to avoid such spam logs when my inverter is offline? after sunset the inverter goes offline but my rest sensor still tries to retrieve data.
I tried to add an availability with a binairy sensor, but it seems like the rest sensor still triggers every minute and ignores that part.
any suggestions?
2026-05-17 01:55:45.377 ERROR (MainThread) [homeassistant.components.rest.data] Error fetching data: http://192.168.2.12/ failed with Cannot connect to host 192.168.2.12:80 ssl:default [Connect call failed ('192.168.2.12', 80)]
2026-05-17 01:56:45.344 ERROR (MainThread) [homeassistant.components.rest.data] Error fetching data: http://192.168.2.12/ failed with Cannot connect to host 192.168.2.12:80 ssl:default [Connect call failed ('192.168.2.12', 80)]
My sensor
- platform: rest
scan_interval: 60
resource: !secret solax_local_ip
payload: !secret solax_local_realtime_payload
method: POST
headers:
X-Forwarded-For: 5.8.8.8
unique_id: solax_rest_local
json_attributes:
- SN
- ver
- type
- Data
- Information
value_template: >-
{% if state_attr('sensor.solax_rest_local', 'SN') is defined %}
Active
{% else %}
Unavailable
{% endif %}
availability: >-
{{ is_state('binary_sensor.inverter_ip', 'on') }}
timeout: 5
