iOS actionable notification
Hi guys,
the automation makes the check of total power consumption and if above 3500w all the wemo switches are turned off. Then a message reaches my iPhone asking which switch I’l like to turn on.
The issue I’m facing is that I receive the message but without any multiple selection. Just the message with no switch choice
Do you have any idea where I’ve done any mistake?
My files:
automations.yaml:
- id: wemo_superano_soglia
  alias: Wemo superano soglia
  initial_state: true
  hide_entity: false
  - above: '3500'
    entity_id: sensor.tot_current_power
    platform: numeric_state
    - service: homeassistant.turn_off
      entity_id: switch.lavastoviglie
      entity_id: switch.lavatrice
      entity_id: switch.forno
    - service: notify.notify
        title: "Attenzione:"
        message: "superato il consumo consentito, cosa vuoi ri-accendere?"
          push:
            badge: 0
            category: 'SCELTAWEMO'
ios.yaml:
push:
  categories:
    - name: sceltawemo
      identifier: 'SCELTAWEMO'
      actions:
        - identifier: 'LAVATRICE_ON'
          title: 'Accendi lavatrice'
        - identifier: 'LAVASTOVIGLIE_ON'
          title: 'Accendi lavastoviglie'
        - identifier: 'FORNO_ON'
          title: 'Accendi forno'
configuration.yaml:
#iOS
ios: !include ios.yaml
Thank you!
The action is normally
      service: notify.ios_<your_device_id_here>
but I see yours is
Did you create a notification group?
I can’t see otherwise what could be wrong…
Hi lolouk44,
with notify.notify every iPhones receive the notifications.
That works.
Anyway I’ve tried also your suggest with no results (notify.ios_<your_device_id_here>)
thanks.
Then I really don’t know why it’s not working.
Have a look at my files in case you spot something I’ve missed…
Thank you for sharing. I check and let you know
Thank you lolouk44, I’ve checked your files and find out that I’ve done some small mistakes in code writing.
Plus I’ve understood from your GitHub how to split automation files into folder.
Thank you!
Great stuff. Care to share what was wrong?
There were mistakes on the use of hyphen [-]
Now is in this way:
configuration.yaml
automation: !include_dir_merge_list automation/
iOS.yaml
push:
  categories:
    - name: Sceltawemo
      identifier: 'sceltawemo'
      actions:
          activationMode: 'background'
          authenticationRequired: yes
          destructive: yes
          behavior: 'default'
          destructive: yes
          behavior: 'default'
          destructive: yes
          behavior: 'default'
\automation\ios.yaml
#- id: wemo_superano_soglia
- alias: Wemo superano soglia
#  initial_state: true
#  hide_entity: false
    above: '3500'
          push:
            badge: 0
            category: "sceltawemo"
#- id: wemo_superano_soglia_con_TV
- alias: Wemo superano soglia con TV
    above: '3200'
  condition:
    condition: and
    conditions:
      condition: state
      entity_id: switch.switch_tv
      state: 'on'
          push:
            badge: 0
#- id: wemo_superano_soglia_con_KODI
- alias: Wemo superano soglia con KODI
    above: '3200'
  condition:
    condition: and
    conditions:
      condition: state
      entity_id: switch.switch_kodi
      state: 'on'
          push:
            badge: 0
#- id: accendi_lavatrice
- alias: Accendi lavatrice
    platform: event
    event_type: ios.notification_action_fired
    event_data:
      actionName: LAVATRICE_ON
    service: homeassistant.turn_on
#- id: accendi_lavastoviglie
- alias: Accendi lavastoviglie
    platform: event
    event_data:
      actionName: LAVASTOVIGLIE_ON
#- id: accendi_forno
- alias: Accendi forno
    platform: event
    event_data:
      actionName: FORNO_ON
Thanks again
Ah the freaking hyphens :joy:
