iOS actionable notifications not working
Hi. I’ve configured a basic actionable notification sent to my mobile companion app, but when I listen for the event data, it does’t show up??? I’ve listened to notify.mobile_app_action and i’ve tried listening to ios.action_fired. Any ideas from anyone?
Post the automation
I use ios_action_fired.
Have you checked traces to determine why it may not be triggering?
whats traces? How do I do that… EDIT: FIGURED IT OUT
Here is my yaml
alias: Deadmans Switch Check-In
description: ""
triggers:
  - trigger: time
    at: "07:00:00"
conditions: []
actions:
  - action: notify.mobile_app_iphone
    metadata: {}
        push:
          sticky: "true"
        sound:
          critical: 1
          volume: 1
        actions:
          - action: CHECKED_IN
            title: Yes, I'm here
      message: hey
      title: dude
  - wait_for_trigger:
      - trigger: event
        event_type: ios_action_fired
        event_data:
          action: CHECKED_IN
    timeout:
      hours: 24
      minutes: 0
      seconds: 0
      milliseconds: 0
    continue_on_timeout: false
  - data:
      entity_id: input_datetime.last_check_in
      timestamp: "{{ now().timestamp() | int }}"
    action: input_datetime.set_datetime
mode: single
try below
description: ""
triggers:
  - trigger: time
    at: "07:00:00"
  - trigger: event
    event_data:
      action: CHECK_IN
conditions: []
actions:
  - if:
      - condition: trigger
        id:
          - time
    then:
      - data:
          message: Are You Here?
            tag: checkin
            actions:
              - action: CHECK_IN
                title: dude
                destructive: true
        enabled: true
    else:
      - if:
            id:
              - iosaction
        then:
          - data:
            enabled: true
          - data:
              message: You have been Checked In
                tag: checkin
            enabled: true
Hey. I got this error msg when trying to put in that yaml;
Message malformed: Unable to determine action @ data[‘actions’][0][‘else’][0][‘then’][0]
I’ve never nested if statements under actions before so this is new territory for me.
EDIT: I got this script working, but for some reason I had to change the event to mobile_app_notification_action ?? There is no ios_action_fired event set up in my HA Platform??
Thanks for you help.
i edited the previous post.
it was missing action “action: input_datetime.set_datetime”
this will survive reboot since if system reboot while automation was “waiting” it would cancel. since it will work based on receiving notification action it works always. Trigger IDs are great
Thanks very much for your help!
