Yes - this issue has many threads on here, but it seems my case might be different since:
The issue exists even with the latest iOS and iOS Beta.
The issue exists both on my local network and externally.
The issue exists both with the IP address and with home assistant.local.
Swiping up on the loading screen does nothing.
The issue exists whether location settings are enabled or not.
Additional details:
When I start clean after deleting the app, the wizard correctly finds my local installation and completes, correctly pulling and populating the external URL from the server information, however when I try and connect I get the dreaded “You’re disconnected” screen. Using duckdns with NGNX and was working fine for years until the past month or two. Accessing the site from my browser (public and local URLs) works fine. Also, not sure if this is at all relevant, but there are about 300 banned IPs in the ip_bans.yaml list (obviously mine is not included).
From your computer browser, go to settings - system - logs - you’ll probably see some warning about it right there in the Core warnings section that the logs open to.
Sure - the only thing there from when I tried logging in with the app yesterday was this:
Log details (WARNING)
Logger: homeassistant.components.http.ban
Source: components/http/ban.py:140
integration: HTTP (documentation, issues)
First occurred: April 17, 2026 at 12:28:58 PM (11 occurrences)
Last logged: April 17, 2026 at 2:36:29 PM
Login attempt or request with invalid authentication from XX.XXX.203.242 (XX.XXX.203.242). Requested URL: ‘/auth/token’. (Home Assistant/2026.4.0 (io.robbie.HomeAssistant; build:2026.1862; iOS 18.5.0) Alamofire/5.8.0)
Login attempt or request with invalid authentication from XX.XXX.207.152 (XX.XXX.207.152). Requested URL: ‘/auth/token’. (Home Assistant/2026.4.0 (io.robbie.HomeAssistant; build:2026.1862; iOS 18.5.0) Alamofire/5.8.0)
Login attempt or request with invalid authentication from XX.XXX.242.166 (XX.XXX.242.166). Requested URL: ‘/auth/token’. (Home Assistant/2026.4.0 (io.robbie.HomeAssistant; build:2026.1862; iOS 18.5.0) Alamofire/5.8.0)
though not sure it’s related since it is from an external IP address and I’m trying to connect locally. (I masked the start of the IP)
still looking for help here. One additional data point, I also cannot browse to https://mydomain.duckdns.org from Safari on my iPhone, though I can access it from a computer.
Solved. For anyone else - the issue was an add blocking app I has installed on my iPhone which ran as a VPN. Whitelisting duckdns.org solved the problem.
I'll add what worked for me here too, since others may find this thread.
Perhaps an unusual situation, but I'm on holidays with a travel router...
So, my app thinks I'm on my local network since the SSID is the same as at home. It tries the local 192.168 address and times out.
I'll just use the browser, not the app, when I'm on this network. I could also set the internal address to the same as the external (no IP).
