IOS Back Tap to invoke Assist asks "Which one?"
I have my iPhone 14 configured to invoke Assist via back tap.
But then I get a drop down prompt at top of screen:
Which one?
Home Assistant
Home Assistant Cloud
Is there a way to resolve this?
I assume I want Home Assistant Cloud (I use Nabu Casa).
NB - I did see another post about this, but it was not applicable to my situation as far as I can tell as they had a newer iPhone and were using it’s action button. (Something about editing a widget, which is not applicable in my scenario that I know of.)
Solved this myself: you edit this new shortcut in the IOS Shortcuts app, specifically you click the right pointing arrow in the circle beside (to the right side of) the shortcut entry (after first having selected the shortcut from the main screen of the shortcuts app) …then you can select the specific option (Home Assistant Cloud is what I wanted) in the Pipeline section.
