Since installing iOS 26.4 Beta 3 I cannot get Home Assistant to load on my IPad ?
Try changing the server to http://homeassistant.local:8123 instead of using your IP address
Thanks that worked
Good that it is solved!
Also: please take the time to mark the post that holds the solution.
You do that by selecting the three dots under the post:
Then select the check box:
By doing so:
- this thread can be useful to other users as well (this thread comes up as solution when starting a thread which is similar to yours).
- this prevents that someone else steps in trying to help
Thanks for giving back to the community! ![]()
