My goal is to create a flow that sends me an iPhone notification when I leave the house with the friendly name of any entities in a group that are open.
It works fine, except for the call service api node doesn’t display the actual payload information. I am sure it’s some formatting, but for the life of me, I can’t figure this out.
Here’s my Node Red code:
"id": "83b0b8f0.06cdf8",
"type": "debug",
"z": "5e7d351f.1f4d7c",
"name": "debug11",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"complete": "payload",
"targetType": "msg",
"x": 660,
"y": 460,
"wires": []
"id": "7ab82e2e.a03d",
"type": "debug",
"name": "debug12",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"x": 880,
"y": 460,
"wires": []
"id": "bffefc8e.2c2ea",
"type": "debug",
"name": "debug13",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"x": 1080,
"y": 460,
"wires": []
"id": "d5240820.f04c08",
"type": "debug",
"name": "debug14",
"active": true,
"tosidebar": true,
"console": false,
"tostatus": false,
"x": 1320,
"y": 460,
"wires": []
"id": "2e051ef8.067ca2",
"type": "inject",
"name": "",
"topic": "",
"payload": "not_home",
"payloadType": "str",
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"x": 180,
"y": 500,
"wires": [
"6105467.d7503b8"
"id": "6105467.d7503b8",
"type": "ha-get-entities",
"server": "266be3ff.3fa20c",
"name": "Grab Open Window/Door Entities",
"rules": [
"property": "entity_id",
"logic": "in_group",
"value": "group.outside_alarm",
"valueType": "str"
"property": "state",
"logic": "is",
"value": "on",
"valueType": "str"
"output_type": "random",
"output_empty_results": false,
"output_location_type": "msg",
"output_location": "payload",
"output_results_count": 1,
"x": 440,
"y": 500,
"wires": [
"a732bd36.7fb9b",
"83b0b8f0.06cdf8"
"id": "771d981d.ee0218",
"type": "trigger-state",
"name": "Left Home",
"exposeToHomeAssistant": false,
"haConfig": [
"property": "name",
"value": ""
"property": "icon",
"value": ""
"entityid": "device_tracker.bjl_iphone_xs",
"entityidfiltertype": "exact",
"debugenabled": false,
"constraints": [
"id": "4h4if2xes8r",
"targetType": "this_entity",
"targetValue": "",
"propertyType": "previous_state",
"propertyValue": "old_state.state",
"comparatorType": "is",
"comparatorValueDatatype": "str",
"comparatorValue": "home"
"id": "zagj77u9wwe",
"targetValue": "",
"propertyType": "current_state",
"propertyValue": "new_state.state",
"comparatorValue": "not_home"
"constraintsmustmatch": "all",
"outputs": 2,
"customoutputs": [],
"outputinitially": false,
"state_type": "str",
"x": 190,
"y": 560,
"wires": [
"6105467.d7503b8"
"id": "a732bd36.7fb9b",
"type": "template",
"name": "Format Friendly Name",
"field": "payload",
"fieldType": "msg",
"format": "handlebars",
"syntax": "mustache",
"template": "{\n The following are open:\n \"{{payload.attributes.friendly_name}}\"\n }\n",
"output": "str",
"x": 700,
"y": 500,
"wires": [
"8280197c.8a75f8",
"7ab82e2e.a03d"
"id": "8280197c.8a75f8",
"type": "join",
"name": "",
"mode": "custom",
"build": "string",
"property": "payload",
"propertyType": "msg",
"key": "topic",
"joiner": ",",
"joinerType": "str",
"accumulate": false,
"timeout": "3",
"count": "",
"reduceRight": false,
"reduceExp": "",
"reduceInit": "",
"reduceInitType": "num",
"reduceFixup": "",
"x": 870,
"y": 500,
"wires": [
"6eaea4f3.21e2bc",
"bffefc8e.2c2ea"
"id": "6eaea4f3.21e2bc",
"type": "api-call-service",
"name": "Notification: \"Window/Door Open\"",
"version": 1,
"service_domain": "notify",
"service": "mobile_app_bjl_iphone_xs",
"entityId": "",
"data": "{\"title\":\"ALERT\",\"message\":\"{payload}\"}",
"dataType": "json",
"mergecontext": "",
"mustacheAltTags": false,
"x": 1160,
"y": 500,
"wires": [
"d5240820.f04c08"
"id": "266be3ff.3fa20c",
"type": "server",
"z": "",
"name": "Home Assistant"
Looks like the message is flowing through fine until the call service node:
Running Hass.io 0.105.3 n a RP4. Help is appreciated.
