iOS widget tap behavior changed
A few days ago my iOS widget tap behavior changed. previously, I could tap any value in the widget and it would simply refresh the current value of that sensor. now, it only opens the app (which is far too heavy of an interaction than I’m looking for)
is this expected or a regression? the option to set tap behavior seems to have been removed from the app. This had been working well for months
Exact same issue for the exact same use case (monitoring solar production etc) did you find a solution? This was working so well
