Home Assistant app now working again in iOS 14 beta 6
Hmm…I have the issue that it takes ages for Siri to control a device which “comes” from HomeAssistant.
Also if I open the Home App it takes up to 40-50 seconds till I can control a device. I’m on beta 7 with Home Assistant 0.114.4.
Any ideas?
Have you tried clicking the buttons in the home App even though it says “No Response/updating” for me clicking the buttons would actually work, but take a little bit to show the proper status… Fwiw, I’m on iOS 14 beta 7, (my primary method of using Siri) Home Assistant 0.114.4, home hub is an iPad with iOS 13.6.1, and the response is much better than it used to be… also someone somewhere mentioned that if your home hub is an iPad it will be much slower when not plugged in, and I would have to agree that when that device is charging the response time is much quicker…
Yes I tried an nothing happened. My Hub is an Apple TV with the latest iOS 13 so shouldn’t be any issue normally.
I think the Siri problem is because it takes to long to update the devices…
I don’t know what happened but from one to another second the delay is drastically shorter Keep you posted.
