I am using MQTT with IoT Link, installed on a windows machine.
I want to run a script that restarts Blue Iris - here is the script to start Chrome - i cannot for the life of me figure out how to restart a program:
my_computer_run_chrome:
alias: "My Computer - Run Chrome"
sequence:
- service: mqtt.publish
topic: "iotlink/workgroup/my-computer/commands/run"
payload: '{ "command": "C:\\Program Files (x86)\\Google\\Chrome\\Application\\chrome.exe", "args": "https://iotlink.gitlab.io", "path": "C:\\Program Files (x86)\\Google\\Chrome\\Application", "user": "", "visible": true, "fallback": true }'
Any ideas?
Thanks.
WallyR
(Wally)
2
You might have to kill the program first.
Windows 10 have a command called tskill.exe in Windows\system32 that can do that.
psyciknz
(Psyciknz)
3
Isn’t blueiris a service? If not I’d look into making it one. Look up the sc command. Then iotlink should just be able to restart the service.
I thought I was the only person that used iotlink. I made some changes to it for a more openHAB based mqtt experience
Thanks, that worked!
Yeah I use it and only just started. Pretty neat solution.
mimuncito
(Mimuncito)
5
Can you share your script’s final version ? Thank you in advance.
Here you go
alias: Server Reboot
sequence:
topic: iotlink/workgroup/server-xyz/commands/reboot
payload: ''
mode: single
And to reboot a virtualbox machine
alias: Server pfsense Reboot
sequence:
topic: iotlink/workgroup/server-xyz/commands/run
payload: >-
{ "command": "C:\\users\\admin\\virtualbox
vms\\pfsense-firewall-restart.bat", "path":
"C:\\users\\admin\\virtualbox vms", "user": "", "visible": true,
"fallback": true }
mode: single
