Hi guys, just moved from docker setup to HA OS and everything should be easier but I’m struggling moving from fail2ban to the included ip filtering function of http integration.
This to enable the banning:
http:
ip_ban_enabled: true
login_attempts_threshold: 5
These will create 2 entities, one with the full content of ip_bans.yaml and the other with the number of bans:
command_line:
- sensor:
command: 'cat /config/ip_bans.yaml'
unique_id: ip_bans
icon: mdi:cancel
scan_interval: 30
- sensor:
command: "grep banned_at /config/ip_bans.yaml|wc -l"
unique_id: ip_banned
icon: mdi:cancel
scan_interval: 30
Then it’s easy to share the result on frontend and make it appear only in case there is some ban:
type: grid
cards:
- type: heading
icon: mdi:cancel
heading: Network Bans
heading_style: subtitle
badges:
- type: entity
show_state: true
show_icon: true
entity: sensor.ip_banned
color: red
icon: mdi:alert-octagram
tap_action:
action: more-info
visibility:
- condition: numeric_state
above: 0
visibility:
above: 0
tap_action:
action: perform-action
perform_action: input_boolean.toggle
entity_id: input_boolean.dashboard_domotica_bans
- type: markdown
content: |2-
## <ha-icon icon="mdi:block-helper"></ha-icon> IP Bannati
{{ states('sensor.ip_bans') }}
visibility:
above: 0
- condition: state
entity: input_boolean.dashboard_domotica_bans
state: "on"
and with:
shell_command:
clear_ipbans: cat /dev/null > /config/ip_bans.yaml
…I can empty the file and unban everybody.
I probably could do a script that gets in input the ip to unban and with some bash-kungfu delete only the two corresponding lines.
Then I can automate the unban in a specific time of the day or after X time the file is updated and so re-create the “temporary” ban as with fail2ban.
BUT the issue is now that after emptying the file, the entire home assistant OS need to be restarted as per documentation.
Is it possible to reload only http integration or some other part of HA to avoid a full reboot?
Maybe some CLI command is enough to reload only the network part?
Otherwise, this is probably a good feature request.
