IP camera to choose
Hi everyone. Trying to get camera work, nothing yet. I am using some russian “digma” cameras. Is it even possible to get working cameras, which are not in this Category Camera https://home-assistant.io/components/camera.generic/ ) list?
Will I make it work if i just get the image by broser whith it’s IP? Or I have to use cameras from the list becouse of “ - platform: generic…”
can be any camera that you can use browser to open.
Configuration from generic cam is ok for that?
you can test by using your camera http to open from browser. If there is display of the camera on the browser.
Then add the generic camera to home-assistant with the same http you have test for your camera.
