Ip rated, mains powered motion sensors?
does anyone here have any personal experience with any ip rated mains powered motion sensor?
I done the usual Googling and come up with several different products but not very much in the way of people’s personal experience regarding usage and home assistant Integration.
I’ve tried the usual battery powered ons like the hue outdoors sensors but the cold weather and repeated triggers are doing a number on battery life, and most of mine are in hard to reach locations so changing the battery can require a cherry picker. so I’m looking to replace them and would value some advice from people who have been using them in the field rather than just reviewing them.
I can hardwire cat 5, the wifi is good and I use zha (some of my core devices are hard coded to zha only, so I’m stuck with it).
what is the good word?
I believe you are not looking for IP20 rated device. If so, you should specify the requirements.
tbh, if someone has a particularly good experience with an ip20 device, or a horror story, it would be interesting to hear. I’ve known ip65 devices fail due to condensation indoors, and devices that say for indoor only use last years outside in exposed locations.
shared knowledge enriches us all.
