Iphone 16 "“Login attempt or request with invalid authentication"
I just bought this iphone 16 and d/l ha from the app store.
I had no problem use the Iphone 11 and web access to HA, not from iphone 16, even using the local address 192.168.1.5:8123.
Was able to access ha on iphone 11, using both local address or Nginx proxy manager. What gives?
Environment:
Both HA and Nginx proxy manager are running in separate docker container.
Ubuntu 2024 with the latest docker.
IOS 18.1.1 Iphone 16 pro
HA version: core 2022.6.7 in both phones. How do I get a 2024 version into iphone, have deleted and reinstalled many times to no avail.
Ok now I have updated the core in the server to 2024.12.1 but the Iphone 16 still has the "unable to connect error, while the iphone 11 is working!
In case some one want to know how do I update ha in docker.
  1. I install docker portainer_ce where HA is installed
  2. access portainer_ce by “ip address”:9000
  3. update HA in the portainer, restart
What should I do now?
Bingo
I read some thing on the net and it was Norton 360 vpn
"If anyone is wondering, it was Norton 360 on my phone preventing the connection. I have since disabled. "
Please mark you above post with the Solution tag. Anyone who has the same issue in the future would be able to see how to fix it immediately.
