trying to setup Home Assistant on a iphone hotspot address
i follow the procedure to setup Home Assistant on Wifi
Raspberrypi as start with Home Assistant , but i cannot navigate to the web page : via the IP 172.30.XX.X:8123
Run âha network infoâ and youâll see the docker address you posted earlier but also under âinterfacesâ youâll see the local IP address you are after.
Then that might be your problem :). There was no image attached to your post, by the way. When you etched your HASSOS image did you follow the instructions for setting up the network?
