iPhone Tailscale Data Loading FOREVER
IPhone SE IOS 26.3.1 Tailscale 1.96.2 … Been remotely using Tailscale on this iphone successfully until somewhere between the end of Feb and beginning of March while I was on the road, this just stopped working completely … I had a bookmark in safari but the original issue was when I clicked on this bookmark, the url flashed then disappeared with a blank screen in Safari … after doing many reboots of all devices and now back home the issue now has changed: when attempting to connect thru safari with the vpn connected, it now shows an HA icon then just spins with the data loading dialog … looking at the tailscale app all 3 links (Iphone, Ha, and MAGIC DNS) have a green dot in front of them … the tailscale main dialog states tailscale is connected and that endpoint is enabled for homeassistant … on the server (ubuntu 22.04.5 LTS) tailscale status suggests there may be an issue with routing (HAOS is running in a Virtual BOX on top of ubuntu) … as stated, this was all working for several weeks … on my 3rd road trip in 2 months it just up and failed and I haven’t been able to find a resolution … chatgpt suggested turning on accept-routes=True on the server but that caused SSH, MQTT, to fail completely, I had to login to the local ubuntu admin terminal and return this setting to false to restore HA functionality for MQTT plus be able to ssh into UBUNTU remotely
here is the issue display in failscale status in ubuntu
Health check:
- Some peers are advertising routes but --accept-routes is false
That is very hard to read…
