IPv6: ADDCONF(NETDEVUP):...Link is not ready (error on install)
trying to boot on a Pi 4B-4GB.
Plugged into router with ethernet. All the connector lights are on. Other ethernet connections to router working fine.
Endlessly repeats error message every 5 minutes
Tried both 32 and 64 image flashes.
Tried reflashing mSD card 3 times. Same result.
Hassio is running, sort of. Hit Return key and logged in using ‘root’, but no real internet connection. repeats error message even after this.
Ideas?
Did you check with your router if you see the Pi connected? Did you create a network config file in USB pendrive and plug it to your Pi before booting up?
This is headless. Are you connecting through a browser on another device on your network to the ip_address:8123 ?
