IR ESPHome Climate control receiving the transmitted codes sent to AC Whirlpool
Hi there,
I have sucesfully configured an ESP-01M with an integrated IR RX and TX ESP-01M. However when I sent a command to the AC to i.e Heat mode, 22 degrees, the aircon receives the message fine but also the IR_TX receives that code sent and messes up the status in the climate card. I would like to keep the receiver enabled but avoid the reading of commands for a second after a TX command is sent. I was thinking on implementing this with a lambda, but I have not found much documentantion in this sense.
Has anyone had this problem before?
this is part of my YAML:
esphome:
  friendly_name: irACcontrol
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: ".............."
ota:
  password: ".............."
wifi:
  ssid: ####
  password: #####
captive_portal:
remote_receiver:
  pin:
    number: GPIO14 #checked
    inverted: true
  dump: all
# Configure the IR LED: this one sends commands to other devices
remote_transmitter:
  pin: GPIO4 #checked
  carrier_duty_percent: 50%
climate:
  - platform: whirlpool
    model: DG11J1-91
    name: "Aire dormitorio "
    receiver_id: rcvr
May you please explain more in details ? how can it mess the card as it’s just data you sent that is the setting applied at AC system and that AC system will also confirm back :wink:
Thanks Vincen fort he response. Sorry I din’t mean that. It’s not messing the climate card in HA, it’s just a feedback loop that is causing issues in the definitive status of the card after the message is sent.
I think the problem is that the IR receiver is having a feedback loop of the message sent by the IR Transmitter, they are 5mm apart from each other.
I was thinking on avoiding IR Receiver messages for some miliseconds after the IR trasmitter sent the code. Using a filter or lambda function?
Sorry but I don’t get it what is the problem there :frowning: esphome handles automatically the fact that it receives also what it sends :sunglasses:
I believe the problem is in the IR Whirlpool platform only. As I have tested with other platforms and they are working fine. It seems that it sends twice the command transmitted but the second command changes state (from HEAT to OFF ) or (From OFF to HEAT)
This is the issue I am facing with Whirlpool:
Also happens with Midea
Good afternoon, I have a Galactic air conditioner in the Whirlpool enclosure. I have the same problem as you, can you please tell me how to solve it?
