Irrigation Sensor Reading (Sprinklers Pi)
How do I get the status (name, enabled, pump & state) of the following JSON endpoint:
This is what I currently have in my sensor.yaml:
- platform: rest
  scan_interval: 10 #7200 Seconds = 2 Hours
  resource: http://10.0.0.50:8080/json/zones
  value_template: >-
    {% for zones in value_json.zones
       if zone.location == 'zones' and name.Title == 'Zone 1' %}
        {{ zone.value | float / 100 }}
    {% endfor %}
  json_attributes:
    - name
    - enabled
    - pump
    - state
  headers:
    Referer: http://10.0.0.50:8080/json/zones
#  unit_of_measurement: '%'
  sensors:
    zone_1_name:
      friendly_name: "Zone 1 Name"
      value_template: '{{ states.sensor.zones.attributes["name"] }}'
    zone_1_enabled:
      friendly_name: "Zone 1 Enabled"
      value_template: '{{ states.sensor.zones.attributes["enabled"] }}'
    zone_1_pump:
      friendly_name: "Zone 1 Pump"
      value_template: '{{ states.sensor.zones.attributes["pump"] }}'
    zone_1_state:
      friendly_name: "Zone 1 State"
      value_template: '{{ states.sensor.zones.attributes["state"] }}'
Here is the endpoint info at http://10.0.0.50:8080/json/zones:
"zones" : [
	{"name" : "Zone 1", "enabled" : "on", "pump" : "on", "state" : "off" },
	{"name" : "Zone 2", "enabled" : "on", "pump" : "on", "state" : "off" },
	{"name" : "Zone 3", "enabled" : "on", "pump" : "on", "state" : "off" },
	{"name" : "Zone 4", "enabled" : "on", "pump" : "on", "state" : "off" },
	{"name" : "Zone 5", "enabled" : "on", "pump" : "on", "state" : "off" },
	{"name" : "Zone 6", "enabled" : "on", "pump" : "on", "state" : "off" },
	{"name" : "Zone 7", "enabled" : "on", "pump" : "on", "state" : "off" },
	{"name" : "Zone 8", "enabled" : "off", "pump" : "off", "state" : "off" },
	{"name" : "Zone 9", "enabled" : "off", "pump" : "on", "state" : "off" },
	{"name" : "Zone 10", "enabled" : "off", "pump" : "on", "state" : "off" },
	{"name" : "Zone 11", "enabled" : "off", "pump" : "on", "state" : "off" },
	{"name" : "Zone 12", "enabled" : "off", "pump" : "on", "state" : "off" },
	{"name" : "Zone 13", "enabled" : "off", "pump" : "on", "state" : "off" },
	{"name" : "Zone 14", "enabled" : "off", "pump" : "on", "state" : "off" },
	{"name" : "Zone 15", "enabled" : "off", "pump" : "on", "state" : "off" }
I just get a blank reply.
I also think that there should be a simpler way to get the values for name, enabled, pump & state.
There would be, if the JSON output would be different…
Your value_template in the rest sensor doesn’t make any sense. You look for zone.location and name.Title, however in your JSON output there’s no location or Title at all. Also what you want to do for the attributes is not possible, to extract attributes like this, they need to be “top-level” fields in the JSON output.
