Is Home Assistant and/or ESP Home the system(s) for me?
I need to give you some background to my requirements, hopefully not too long winded.
Over the last 3 years mainly as a hobby, I have been building a project for the monitoring of my home’s central heating and hot water systems with the view to improving efficiency. I based the system on the ESP32 and although far from an expert I have become reasonably proficient at programming the ESP32 using Arduino IDE and coding in C++. I attach a simple sketch of the existing network, but briefly I have 3 local ESP32’s with hardwired I/O for monitoring temperatures (14), digital inputs (18) and digital outputs (8). These 3 ESP32’s are connected to a Master ESP32 by ESP-NOW (on board Wi-Fi). The Master ESP32 collates and manipulates monitoring data and forwards the received data to a 5th ESP32 via a hardwired UART serial link. This communications ESP32 then extracts the data from the serial link and processes it for sending by Wi-Fi to the Blynk IOT Platform.
For those not aware Blynk IOT is a proprietary software platform that allows the user to easily develop their own dashboards and controls and can connect to it remotely from a phone. I have this system working successfully, however, because I am using the free version with limited capability, I have not been able to take this project any further. Purchasing a license for the pro version at circa. $130 per month is clearly not an option.
Unless you have any other suggestions, Home Assistant looks to be the way to go. I am extremely reluctant to start again and throw away all the work I have done and replace the existing code with Yaml (even if this is possible). So, I have a few questions:
  1. Can I connect the communications ESP32 direct to Home Assistant without the use of ESP Home, if so, what method would you recommend, examples would be helpful?
  2. Is there an issue with the quantity of data (14 temperature sensors and 26 digital I/O) that I want to transmit to HA using a single device?
  3. If I need to use ESP Home, how do I format my data in the UART serial link for ESP Home to read this data, I have seen limited examples on this and am currently totally confused, give me C++ any day?
Thankyou.
Yes, using MQTT you should be able to access your data in HA. It will depend on how your existing code / data is setup in the ESP’s.
Won’t be an issue.
You can actually include C++ code into ESPhome YAML files. This could be a nice way to migrate your existing project to an ESP which talks to HA through it’s native API, but not essential.
Yes, multiple ways. MQTT, HTTP requests, BLE, UDP…
