I have a webpage running on my server on a non-standard port (lets say 11111), and I want that to be in an iFrame card. But I keep getting “www.hompeage.com:11111 denied connection”. (Or something to that effect, it’s in Norwegian). Does that mean that I can’t embed a webpage unless it is on port 80?
Edit: I have seen some posts about it, but they were mostly about port 3000 for some camera stuff and https, noen of which helps me.
No, both are HTTP, not HTTPS. But maybe password may be the problem? The case is:
On my cabin’s Home Assistance instance on one non-standard port I want to have an iFrame that opens the house Home Assistant on another non-standard port.
But is it possible that the denial is not because of the port, but because it’s not possible to type in a password in an iFrame?
Edit: The reason is that I wanted to control something in the house from the cabin, and it seemed like the easiest way to do it, since I don’t have them linked with remote Home Assistant or something like that. I do have a link between the places in SoftEther, so maybe I should think about forwarding MQTT between the two servers instead?
Edit 2: I tried with another web service I have running, which needs a password, and that worked. So I’m still suspecting the non-standard port.
Thanks, that explains it. Annoying, but I’ll have to find another way to do this, probably with MQTT forwarding.
Edit: Not necessary, actually. I already had a broker running on the server in the house that I don’t use anymore, but the cabin server had access to that over the SoftEther link. But I had to go via Node-RED, for some reason I don’t think Hass supports multiple MQTT brokers.
